Stress or Strain data not available for nodes of REINF264
    • mer153
      I want to select nodes on a reinforcement line body (REINF264) using the line of code below:
      nsel,R,S,EQV,0
      This doesn't select any nodes. However, if I change the criterion to displacement (nsel,R,U,X,0), then it can select the required nodes based on the defined criterion on the line body.
      Why using the stress or strain criterion, I cannot select any nodes? My conjecture is that the stress or strain values are not either available or defined for these nodes. Is this correct?
      Thank you in advance for any help you can provide.
    • Bill Bulat
      Yes, it looks like REINF264 calculates only component stress results:
    • mer153
      Dear Bill,
      Thank you for your help. This makes a lot of sense.
      NSEL command for the stress only accepts the following components:
      X, Y, Z, XY, YZ, XZ  ---> Component stress.
      1, 2, 3 ---> Principal stress
      Eqv ---> Equivalent stress
      Would you please tell me how we can get the principal stress values (Sx in your figure) if our line elements are oriented in different directions (not necessarily in the X direction).
      Thank  you
    • mer153
      If I remove the component term “X” and update the code as (nsel,R,S,,4000), then the code works. What I want to do after selecting these nodes is to find elements that all their nodes are part of the selected list of nodes and kill these elements. However, now I have two other problems. Please let me know if you suggest creating a new post for these questions.
      My first question is why there is no correspondence between the calculated stress values and the defined criterion for selecting the nodes. I defined the stress threshold of 4000 (I am not sure if the units are Pa) for the selection of the nodes of REINF elements and performed the simulation. I expected to see that when the max principal stress of the REINF elements exceeds 4000 Pa, the solver selects these elements to apply further operations on them using the next lines of code. However, I can see that they are selected even if the stress values of the REINF elements are much lower than this threshold.
      I want to perform the EKILL command on the elements that have the selected node in the previous step. So, I added the following lines to my code (esln,S,1, ekill, all). Although the ESLN command options “,1” is stating that only elements that all their nodes are selected by the NSEL command should be selected, I see that some neighboring solid264 elements are also selected, and EKILL command is performed on them as well. This is happening while before using the (nsel,R,S,,4000) I selected only REINF264 elements by (esel,s,type,,3). Type 3 elements in the ELIST are REINF264 elements.
      I can share an example case with you through ANSYS Customer portal if you deem it helpful.
    • Bill Bulat
      The APDL test case input at the bottom of this post illustrates a way, by selecting discreet REINF264 element table stress results (rather than nodes), to identify fibers whose SX stresses have exceeded some allowable stress. SX is always the axial component of REINF264 stress (regardless of the orientation of the REINF264 relative to the global X axis).
      Copy the APDL below into a text file and read that text file into an interactive MAPDL session with the /INPUT command.
      An alternative to using EKILL might be to define a material damage law for your REINF264:
      I can see from the table below that material damage laws are supported by REFINF264:
      Yet another (probably easier) option might be to define bilinear isotropic or kinematic hardening laws for your REINF264 (I see these options in the table above too).
      fini
      /cle
      /vie,1,1,1,1
      /vup,1,z
      /esha,1
      /pnu,type,1
      /num,1
      /sys,del file*.png
      /title,FIBER REINFORCED CANTILEVER BEAM
      C*******************************************
      C*** PARAMETERS
      l=0.100 ! LENGTH
      t=0.005 ! THICKNESS
      w=0.010 ! WIDTH
      a_f=(t/10)**2 ! FIBER CROSS SECTION AREA
      E_m=2e11/1e3 ! MATRIX ELASTIC MODULUS
      nu_m=0.3 ! MATRIX POISSON'S
      E_f=2e11/1e1 ! FIBER ELASTIC MODULUS
      nu_f=0.2 ! FIBER POISSON'S
      esz=t/5 ! MATRIX MESH SIZE
      dvz=5 ! MESH DIVISIONS IN Z (THICKNESS) DIRECTION
      u_tip=0.01 ! ENFORCED DISPLACEMENT OF BEAM TIP
      s_failure=0.15e9 ! FIBER FAILURE STRESS
      C*** MODEL
      /prep7
      n,1,,w/2,t/2 ! REMOTE POINT NODES
      n,2,l,w/2,t/2
      bloc,,l,,w,,t ! BEAM GEOMETRY
      et,1,185 ! MATRIX ATTRIBUTES
      mp,ex,1,E_m
      mp,nuxy,1,nu_m
      lsel,s,leng,,t ! MESH
      lesi,all,,,dvz
      alls
      vmes,all
      C*** REMOTE PTS AT BEAM ENDS
      et,2,174
      keyo,2,4,1 ! FORCE DISTRIBUTED
      keyo,2,2,2 ! MPC
      keyo,2,12,5 ! BONDED
      et,3,170
      keyo,3,2,1 ! USER-SPECIFIED PILOT NODE CONSTRAINT
      keyo,3,5,3 ! SHELL-SOLID
      r,2
      real,2
      type,2
      nsel,s,loc,x
      nsel,u,node,,1
      esurf
      type,3
      tsha,pilo
      alls
      e,1
      d,1,all
      et,4,174
      keyo,4,4,1 ! FORCE DISTRIBUTED
      keyo,4,2,2 ! MPC
      keyo,4,12,5 ! BONDED
      et,5,170
      keyo,5,2,1 ! USER-SPECIFIED PILOT NODE CONSTRAINT
      keyo,5,5,3 ! SHELL-SOLID
      r,4
      real,4
      type,4
      nsel,s,loc,x,l
      nsel,u,node,,2
      esurf
      type,5
      tsha,pilo
      alls
      e,2
      d,2,ux
      d,2,uy
      d,2,uz,-u_tip
      d,2,rotx
      d,2,roty
      d,2,rotz
      C*** REINFORCING
      et,6,264
      mp,ex,6,E_f
      mp,nuxy,6,nu_f
      sect,6,reinf,disc
      secd,6,a_f,edgo,1,0.5,0.5,0.5,0.5
      mat,6
      secn,6
      esel,s,type,,1
      ereinf
      esel,s,ename,,264
      eplo
      C*** SOLVE
      /solu
      nsub,5,5,5
      outr,all,all
      nlge,on
      alls
      solv
      fini
      C*** POST PROCESS REINF264
      /post1
      set,last
      esel,s,ename,,264
      plns,s,x,2
      /sho,png $plns,s,x,2 $/sho,close $/wait,2
      etab,sx,s,x
      esel,u,etab,sx,-s_failure,s_failure
      plns,s,x,2
      Best,
      Bill
Viewing 4 reply threads
