Stress strain hysteris loop on Mechanical APDL
    • Yadukrishnan Satheesan
      Hi, I am looking to simulate uniaxial cyclic loading on a specimen to generate the stress-strain hysteris loop through the loading and unloading phase. I am considering multi-linear hardening for plasticity. Is it possible to achieve this graph using Mechanical APDL?
    • John Doyle
      What is the source of the hysteresis?  Is it rate dependent?  Is it large strain or small strain?  Is it like ratchetting and shakedown?  If so, perhaps you need a Chaboche plasticity model.  Please refer to Section 4.4.4.2.3 of the MAPDL Material Reference Guide for more details.
    • Bill Bulat
      If you don't intend to mimic the shakedown of ratcheting phenomena that John mentioned...
      if you're content to model material response that does not change each cycle, then the input below might suffice your needs:
      fini
      /cle
      /vie,1,1,1,1
      /vup,1,z
      /pbc,u,,1
      /sys,del file*.png
      C******************************************
      C*** PARAMETERS
      l=0.100 ! LENGTH
      w=0.015 ! WIDTH
      t=0.005 ! THICKNESS
      E=2e11 ! ELASTIC MODULUS
      Sy=2.5e8 ! YIELD STRESS
      P=23e5 ! APPLIED PRESSURE
      C*** MODEL
      /prep7
      bloc,,l,,w,,t ! GEOMETRY
      et,1,185 ! ELEMENT TYPE, MESH
      vmes,all
      nsel,s,loc,x ! CONSTRAINTS
      nsel,a,loc,x,l
      nsel,r,loc,z
      d,all,uz
      nsel,r,loc,y
      d,all,uy
      nsel,r,loc,x
      d,all,ux
      mp,ex,1,E ! DEFINE ELASTIC MODULUS
      TB, PLASTIC,1,,4,MISO ! DEFINE MULTILINEAR ISOTROPIC HARDENING
      TBPT, ,0,1.00*Sy ! YIELD STRESS
      TBPT, ,0.00005,1.10*Sy ! FIRST STRAIN, STRESS POINT
      TBPT, ,0.00105,1.20*Sy ! SECOND STRAIN, STRESS POINT
      TBPT, ,0.00305,1.25*Sy ! THIRD STRAIN, STRESS POINT
      tbli,all,all
      fini
      C*** SOLVE
      /solu
      autots,off
      nsub,250
      outr,all,all
      nlge,on
      /title,STEP 1: Apply Pressure
      nsel,s,loc,z,t,
      sf,all,pres,P
      alls
      save
      solve
      /title,STEP 2: Ramp Pressure to Zero
      nsel,s,loc,z,t,
      sf,all,pres,0
      alls
      save
      solve
      /title,STEP 3: Reverse Pressure
      nsel,s,loc,z,t,
      sf,all,pres,-P
      alls
      save
      solve
      /title,STEP 4: Ramp Pressure to Zero
      nsel,s,loc,z,t,
      sf,all,pres,0
      alls
      save
      solve
      /title,STEP 5: Apply Pressure
      nsel,s,loc,z,t,
      sf,all,pres,P
      alls
      save
      solve
      fini
      C*** POSTPROCESS
      /post1
      plns,eppl,eqv
      /sho,png $plns,eppl,eqv $/sho,close $/wait,2
      fini
      /post26 ! PLOT STRESS VERSUS STRAIN HYTERESIS LOOP
      ansol,2,node(l/2,,-t),s,x ! SX: X COMPONENT ELASTIC STRESS
      ansol,3,node(l/2,,-t),eppl,x ! EPPLX: X COMPONENT PLASTIC STRAIN
      add,4,2,3,,eptot,,,1/E,1 ! TOTAL X COMPONENT STRAIN = SX/E + EPPLX
      /axl,x,Total Strain
      /axl,y,X Component Stress
      xvar,4
      plva,2
      /sho,png $plva,2 $/sho,close
      /eof
        Hi Biil,
        I am bit confused in implementing the cyclic load. Instead of ramping pressure up and down at each step, I want to used cyclic load with ratcheting phenomena, for example, 100 cycles of stress ratio -1 with frequency of 2. I had a look at Chaboche plasticity model, I will be alright to simulate it but I am not sure to implement the cyclic load.
      Thank you Bill. I want to mimic ratcheting on my model as well but this would really help me to kick start my modelling.
      Kind regards,
      Yadu
Viewing 3 reply threads
