Stresses in List Data in APDL are not available
    • Abdullah AlBashrawi
      I made the model, and the APDL has given me a message that says "Solution is done". I can plot the stress result, the only problem is when I try the "List result > Nodal Solution" command. When I pick the von mises' stress to be simulated, it gives  the following error " PRINT S    NODAL SOLUTION PER NODE
       *** WARNING ***                         CP =      23.672   TIME= 12:57:04
       No data is available for the selected model or data location
       specifications."
      Any help is greatly appreciated
    • Manish Dubey
      Could you try the following commands as shown below,
      /POST1
      SET,LAST
      PLESOL, S,EQV, 0,1.0
        It just plotted the results, and the List result still does not work
    • Mike Rife
      Hi Abdullah AlBashrawi
      MAPDL does not write mid-side node results to the result file.  It calculates the values as needed (from the corner nodes).  If you have selected only mid-side nodes, then tried to list a result you would get that error message.  Can you post the listing of all the post-processing commands used up to listing the result?
      Mike
