LS Dyna
LS Dyna
Strike task LS-Dyna ACT
    • javat33489
      Hello friends. My task is two cylinders hit, inside of them there are teeth at an angle. First they hit and then they slide. I made only a 1/10 section with one tooth to solve this problem quickly. But I can't fix a chainring that falls so that it slides after the impact. If I use displacement then the cylinder will not slide along the axis. How to correctly set the movement of a cylinder that is falling?
      In a static calculation, I could set a contact without friction here, but in LS-Dyna it is not
      view from above:
    • Chris Quan
      Not quite sure what you are trying to do. Will frictionless contact help here?
    • javat33489
      There is no frictionless contact in ls-dyna.
      I would like to use it too.
      Therefore, I am looking for ways to make the cylinder segment slide along the ledge around its axis after the impact
