Structural Analysis on ACP
    • Muhammed
      Hello everyone,
      I want to make a structural analysis with metallic and composite materials.
      The geometry is given below. There is a CFRP plate and stainless steel ribs at the bottom side.
    • peteroznewman
      If you have the orthotropic material properties for the CFRP composite plate, and you don't need to look at failure between layers of the composite plate, then you can work with just Static Structural to determine the deformation of the structure.n
    • Muhammed
      Thanks for the reply! nI need to see failure behavior between layers. So, I have to continue with ACP, right?n
    • peteroznewman
      Yes, if you need to see failure between layers, you must use ACP.n
    • Muhammed
      Thank you very much.n
Viewing 4 reply threads
