Structural Analysis on Cylindrical Body Due to Wind Load
    • M Usman
      Hi everyone, hope you are going well. I have done structural analysis on the circular shape body using two different approaches that are listed as below;
      Cad Model Including Simplified Conceptual Cad  Model of Aluminum Frame  with PTFE Plate at Front
      Cad Model Including Actual Manufactured Cad Model of Aluminum Frame with PTFE Plate at Front
      Note:
      Meshing is same in both cases
      Boundary Conditions- Body Weight, Fixed Support & Drag Force due to wind at Front Plate
      Want to check deformation & Von Mises Stresses
      Results in case of First Approach:
      Results in case of Second Approach:
      Please guide me about the difference in results on same problem
      Why results are varying when problem is same, just approaches were changed?
    • Sahil Sura
      Hello M Usman,
      I see you've already posted your query on the forum, Structural Analysis of Cylindrical Body under Wind Loads (ansys.com); For better resolution of the query, please avoid duplication of the posts, our engineers will get back to you as soon as possible assisting your concern.
      Hope this helps!
      Thanks,
      Sahil
      For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
      If you are not able to open the links, refer to this forum discussion: How to access the ANSYS Online Help
