August 10, 2017 at 6:53 pm
August 10, 2017 at 6:59 pm
Vishal Ganore
Ansys EmployeeHi, thanks for uploading the tutorial. Could you please also upload geometry file (CAD) for students to get started?
August 10, 2017 at 7:16 pm
svecchi
Ansys EmployeeThe geometry file (CAD) is created in the tutorial by the student. This is done in many of the tutorials, the tutorials which require a geometry will have the appropriate file attached.
August 10, 2017 at 7:25 pm
Vishal Ganore
Ansys EmployeePerfect. Thanks.
October 25, 2017 at 7:52 pm
tnegem
SubscriberI am new to Ansys and I am still trying to learn everything I can, Would u please let me know why did you use Hexahedrons instead of just Automatic meshing(which is Trihedrons) ? Also what is the use of deciding of face sizing?
wierd thing is that I am obtaining 1303Psi for Max stress YY but my equivalent stress is different than your specially the average is twice as high
- I’m a starter
- YouTube tutorial files
- Fluid Flow – Lid Driven Cavity
- Thermal – Heat Conduction in a Cylinder
- Fluid Flow – Turbulent Flow Over a Backward Facing Step
- Fluid Flow – Taylor-Couette Flow between Rotating Cylinders
- Magnetics-Permanent Magnetic Circuit with Air Gap
- The project files directory doesn’t exist
- vibration
- Process ‘3dedy’ terminated abnormally. It may have run out of memory or could have been killed by..
2524
2066
1285
1096
459
