September 26, 2018 at 11:58 pm
zein.elserfy
SubscriberI am using ICEM in order to generate a c mesh over aerofoil but I have problems with mesh quality and orthogonality quality. I have tried to use hexahedral smooth to make the control volumes close to aerofoil with low orthogonality quality more smoother but after using the hexahedral smooth the mesh become worse
September 27, 2018 at 9:21 am
Keyur Kanade
Ansys EmployeeCan you please insert few images?
Also you can have a look at
Keyur
September 27, 2018 at 9:26 am
zein.elserfy
Subscriberhave you seen the attached image ?
September 27, 2018 at 10:07 am
raul.raghav
SubscriberThe association seems to have been messed up. Could you check your associations again and then try smoothing your mesh? And could you post a screenshot of your smoothing settings? -
September 27, 2018 at 11:19 pm
zein.elserfy
SubscriberI have attached a copy of the smooth setting I keep the default setting except for release orthogonality/initial heigh options in which the aerofoil curves are chosen.
for the association, all the curves are associated with edges
September 28, 2018 at 1:31 pm
raul.raghav
SubscriberCould you attach a screenshot of your pre-smoothened mesh highlighting the region with Quality 0.66 to 0.83?
Do you have any points in your geometry? If you do, have you associated them accurately? The smoother works based on the input mesh and even the slightest disassociation will cause a lot of issues.
Could you share your workbench archive file so we could take a quick look into it?
September 29, 2018 at 2:45 am
September 29, 2018 at 2:48 am
zein.elserfy
Subscriberhttps://drive.google.com/open?id=1ZkPePQN1ucxbeUmd9Y83hkY270SGpsUp
this the link for icem project file
September 29, 2018 at 2:55 am
zein.elserfy
Subscriberthe cells with low orthogonal quality are those on the aerofoil as I am using y=6e-8 m to get yplus=1
October 1, 2018 at 11:52 pm
raul.raghav
SubscriberThe link you shared contains only the project file and the mesh file. Can you zip the entire folder including the .blk file in it.
October 2, 2018 at 2:36 am
zein.elserfy
Subscriberhi Rahul,
I have attached the zip file and uploaded it on the same link.
best regards
Zein
October 17, 2018 at 5:15 am
zein.elserfy
Subscriberhi Rahul;
Have you check the files?
best regards
Zein
October 30, 2018 at 11:43 pm
zein.elserfy
Subscriberdoes anyone have a solution for that problem
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2532
2066
1285
1104
459
