July 27, 2019 at 4:45 am
vspz5
Subscriberi want to simulate the pitching of airfoil in still medium,after some iterations i got the floating point exception error ,dont know where i was going wrong,can anyone help me out?
July 29, 2019 at 2:06 pm
Ansys EmployeeLook at the results shortly before the model fails. Is the model well converged, and is the airfoil still at a sensible angle of attack?
July 29, 2019 at 2:31 pm
rachels1001
SubscriberA floating point exception normally comes from an error at a core when you try to do something impossible with a floating point number, like divide by zero. If you look at your console output before the model fails, you'll probably see warnings about some variable reaching a limitation.
July 30, 2019 at 6:04 am
vspz5
Subscriberfirst of all thank you for ur reply sir,
i was dealing with transient case,yes the solution is converged and after some iterations i got this error.i was doing my analasys in still medium (0 velocity) so i didn't concerned abt the angle of attack.
July 30, 2019 at 2:46 pm
Ansys EmployeeIf there's no flow what are you monitoring?
@cvelikonja correct, and it's a shame I can't like your comment.
2524
2066
1279
1096
457
