Ansys Products
Ansys Products
Stuck at load step 1
    • H Nor
      I have a problem of unconstrainted model with error "  *** ERROR ***     SUPPRESSED MESSAGE    CP =     286.375   TIME= 17:51:27
       There are 2 small equation solver pivot terms (e.g., at the UX degree
       of freedom of node 20502).  Please check for an insufficiently
       constrained model. "
      This is a half model of interior beam column joint. i am not sure how to fix it.
      from the J12_1.out file.
      *****  MAPDL SOLUTION ROUTINE  *****
       PRINTOUT RESUMED BY /GOP
                            L O A D   S T E P   O P T I O N S
         LOAD STEP NUMBER. . . . . . . . . . . . . . . .     1
         TIME AT END OF THE LOAD STEP. . . . . . . . . .  10.000
         AUTOMATIC TIME STEPPING . . . . . . . . . . . .    ON
            INITIAL NUMBER OF SUBSTEPS . . . . . . . . .     5
            MAXIMUM NUMBER OF SUBSTEPS . . . . . . . . .    10
            MINIMUM NUMBER OF SUBSTEPS . . . . . . . . .     1
         MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS. . . .   200
         STEP CHANGE BOUNDARY CONDITIONS . . . . . . . .    NO
         LINE SEARCH . . . . . . . . . . . . . . . . . .    ON
         TERMINATE ANALYSIS IF NOT CONVERGED . . . . . .YES (EXIT)
         CONVERGENCE CONTROLS
            LABEL   REFERENCE    TOLERANCE  NORM     MINREF
             F       0.000       0.2500E-01   2      0.000
             U       0.000       0.2500       2      0.000
         COPY INTEGRATION POINT VALUES TO NODE . . . . .YES, FOR ELEMENTS WITH
                                                        ACTIVE MAT. NONLINEARITIES
         PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
         DATABASE OUTPUT CONTROLS
            ITEM     FREQUENCY   COMPONENT
            NSOL        -10
            RSOL        -10
            NLOA        -10
            STRS        -10
            EPEL        -10
            EPPL        -10
           FORCE CONVERGENCE VALUE  =   3408.      CRITERION=   85.21
        Process memory allocated for solver              =    57.210 MB
        Process memory required for in-core solution     =    54.905 MB
        Process memory required for out-of-core solution =    24.003 MB
       *** NOTE ***                            CP =       4.203   TIME= 21:48:59
       The Distributed Sparse Matrix Solver is currently running in the
       in-core memory mode.  This memory mode uses the most amount of memory
       in order to avoid using the hard drive as much as possible, which most
       often results in the fastest solution time.  This mode is recommended
       if enough physical memory is present to accommodate all of the solver
       data.
         TIME AT END OF THE LOAD STEP. . . . . . . . . .  20.000
            INITIAL NUMBER OF SUBSTEPS . . . . . . . . .500000
            MAXIMUM NUMBER OF SUBSTEPS . . . . . . . . .  1000000
            NSOL        -10
            RSOL        -10
            NLOA        -10
            STRS        -10
            EPEL        -10
            EPPL        -10
           FORCE CONVERGENCE VALUE  =   134.3      CRITERION=   3.357
        Process memory allocated for solver              =    55.061 MB
        Process memory required for in-core solution     =    52.856 MB
        Process memory required for out-of-core solution =    23.852 MB
       *** NOTE ***                            CP =       5.562   TIME= 21:49:01
       data.
         TIME AT END OF THE LOAD STEP. . . . . . . . . .  30.000
            NSOL        -10
            RSOL        -10
            NLOA        -10
            STRS        -10
            EPEL        -10
            EPPL        -10
           FORCE CONVERGENCE VALUE  =   268.6      CRITERION=   6.715
       *** NOTE ***                            CP =       6.719   TIME= 21:49:04
       data.
         TIME AT END OF THE LOAD STEP. . . . . . . . . .  40.000
            NSOL        -10
            RSOL        -10
            NLOA        -10
            STRS        -10
            EPEL        -10
            EPPL        -10
           FORCE CONVERGENCE VALUE  =   402.9      CRITERION=   10.07
       *** NOTE ***                            CP =       7.953   TIME= 21:49:05
       data.
         TIME AT END OF THE LOAD STEP. . . . . . . . . .  50.000
            NSOL        -10
            RSOL        -10
            NLOA        -10
            STRS        -10
            EPEL        -10
            EPPL        -10
           FORCE CONVERGENCE VALUE  =   537.2      CRITERION=   13.43
       *** NOTE ***                            CP =       9.328   TIME= 21:49:07
       data.
         TIME AT END OF THE LOAD STEP. . . . . . . . . .  60.000
            NSOL        -10
            RSOL        -10
            NLOA        -10
            STRS        -10
            EPEL        -10
            EPPL        -10
           FORCE CONVERGENCE VALUE  =   671.5      CRITERION=   16.79
       *** NOTE ***                            CP =      10.547   TIME= 21:49:09
       data.
         TIME AT END OF THE LOAD STEP. . . . . . . . . .  70.000
            NSOL        -10
            RSOL        -10
            NLOA        -10
            STRS        -10
            EPEL        -10
            EPPL        -10
           FORCE CONVERGENCE VALUE  =   805.8      CRITERION=   20.14
       *** NOTE ***                            CP =      11.781   TIME= 21:49:12
       data.
         TIME AT END OF THE LOAD STEP. . . . . . . . . .  80.000
            NSOL        -10
            RSOL        -10
            NLOA        -10
            STRS        -10
            EPEL        -10
            EPPL        -10
           FORCE CONVERGENCE VALUE  =   940.1      CRITERION=   23.50
       *** NOTE ***                            CP =      12.922   TIME= 21:49:13
       data.
         TIME AT END OF THE LOAD STEP. . . . . . . . . .  90.000
            NSOL        -10
            RSOL        -10
            NLOA        -10
            STRS        -10
            EPEL        -10
            EPPL        -10
           FORCE CONVERGENCE VALUE  =   1074.      CRITERION=   26.86
       *** NOTE ***                            CP =      14.094   TIME= 21:49:16
       data.
       FINISH SOLUTION PROCESSING
Viewing 0 reply threads
