March 17, 2022 at 6:58 am
adonph
Subscribersuccessfuly downloaded ansys 2022 R1 but during solution click solve there is a ANSYS license not available - number of demo users reached. Please help.
March 23, 2022 at 12:41 pmGeorge Karnos
Ansys EmployeeMake sure only 1 instance of Workbench/Mechanical is running.
Under %TEMP%\.ansys, you will see .out files.
One should exist for mechanical.
Can you check that file and post the contents of the error.
March 23, 2022 at 2:42 pmadonph
SubscriberSir IT already fix this issue. this is closed and running thanks.
March 23, 2022 at 2:45 pmGeorge Karnos
Ansys EmployeeExcellent!
Viewing 3 reply threads- The topic ‘student ansys 2022 R1 ANSYS license not available max number of demo users reached.’ is closed to new replies.
Trending discussions- Crash with Exit code 1073741819
- M1 Mac Issues
- Stair-stepping of all boundary layers occured at 1 locations
- MS ASP.NET Hosting Bundle 6.0.8 error on install
- ANSYS STUDENT 2023 – R2 OPENS INSTEAD OF R1
- GPU License
- “Maximum licensed number of demo users already reached” for Ansys 2023 student
- Can We Export Files (step, iges, stl) from Student Version of Spaceclaim ?
- Terminate the Fluent meshing forcefully.
- Error in Ansys workbench 2023 R2 since installed
8808
4658
3155
1688
1480
