Ansys Products
Ansys Products
Student license SpaceClaim problem
    • Dadojin
      hello,
      I have just downloaded and installed the 2020R1 Ansys student version, but somehow cannot run the SpaceClaim - because of the licence issues. See the enclosed printscreen.
      Where can I get the SpaceClaim licence?
      thank You,
      kind regards,
      Daniel
    • tsiriaks
      Hi Daniel,
      Could you post the image inline with text ? Because ANSYS employees are not allowed to download attachment.
      Thanks,
      Win
    • Dadojin
      hello Win,
      it says:
      ANSYS LICENSE MANAGER ERROR
      Capability ANSYS SpaceClaim Direct Modeller does not exist in the ANSYS licensing pool.
      No specified user license preferences match available products in the specified licence path:
      ANSYSLI_SEREVRS:
      FLEXlm Servers: E: ... and the path to the file student.lic.
      when I open the file in text editor, it seems there is no license for SpaceClaim:
      it contains only:
      # The following key is for 'ANSYS Academic Teaching Introductory'
      INCREMENT aa_t_i ansyslmd 9999.9999 31-jan-2021 uncounted
      # The following key is for 'ANSYS AIM Student'
      INCREMENT aa_s_aim ansyslmd 9999.9999 31-jan-2021 uncounted
      # The following key is for 'ANSYS Discovery Live Student Version'
      INCREMENT aa_s_disc ansyslmd 9999.9999 31-jan-2021 uncounted
      Thank You,
      Daniel
    • Dadojin
    • tsiriaks
      That's odd. This looks good.
      Try closing all ANSYS applications and running the following command in CMD Prompt
      move "%appdata%ansys" "%appdata%ansys.old"
      If this doesn't help, post the output of the following command
      "%awp_root201%..Shared FilesLicensingwinx64ansysli_util" -checkout SPACECLAIM
      thanks,
      Win
    • Dadojin
      thank You,
      the first CMD command worked - it has mooved something and now the SpaceClaim starts
      have a nice day,
      Daniel
    • tsiriaks
      Perfect ! Please mark the post that helped you resolves the issue as 'Is Solution' , so others with same issue could refer to it.
      Thank you and have a good day,
      Win
Viewing 6 reply threads
