September 8, 2022 at 11:45 am
r10543101
SubscriberHello
When I use fluent in workbench
Geometry and Mesh both work fine
But in the Set step, it does not work properlyThe message in the Set console
Welcome to ANSYS Fluent 2022 R2Copyright 1987-2022 ANSYS, Inc. All Rights Reserved.Unauthorized use, distribution or duplication is prohibited.This product is subject to U.S. laws governing export and re-export.For full Legal Notice, see documentation.Build Time: May 27 2022 08:52:29 EDT Build Id: 10212Connected License Server List:--------------------------------------------------------------This is a student version of ANSYS FLUENT. Usage of this productlicense is limited to the terms and conditions specified in your ANSYSlicense form, additional terms section.--------------------------------------------------------------Host spawning Node 0 on machine "LAPTOP-KN02JFQD" (win64).==================================================================================== BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 0 PID 29344 RUNNING AT LAPTOP-KN02JFQD= EXIT STATUS: -1073741515 (c0000135)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 1 PID 18396 RUNNING AT LAPTOP-KN02JFQD= EXIT STATUS: -1073741515 (c0000135)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 2 PID 11968 RUNNING AT LAPTOP-KN02JFQD= EXIT STATUS: -1073741515 (c0000135)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 3 PID 4568 RUNNING AT LAPTOP-KN02JFQD= EXIT STATUS: -1073741515 (c0000135)===================================================================================When I turn back to the workbenchIt says" Fluent Application cannot be verified to connect"Why is this happening?
I need to finish my master's thesis urgently
Thank you..! -
September 8, 2022 at 12:34 pm
George Karnos
Ansys EmployeeCan you try turning off your firewall software to test if something is being blocked?
September 9, 2022 at 10:45 am
r10543101
SubscriberSorry, I try turning off my firewall .
But it's still doesn't work.
September 9, 2022 at 3:21 pm
George Karnos
Ansys EmployeeIs this a new installation, or did it work before?
Do any errors exist int the install.log located under:
C:\Program Files\ANSYS Inc\ANSYS Student
Or, does an install.err exist? What is the contents? -
September 10, 2022 at 5:20 am
r10543101
SubscriberAt the beginning of the download can be used, after using a month this happens.
The following content is found in the folder:
>>>--------------------------------------->ANSYS安装: 週四 八月 25 12:21:12 2022版本: 2022 R2###### Error #######Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\framewrk\WINX64.7z:'"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\framewrk\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 2###### Error #######Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\cpythnew\WINX64.7z:'"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\cpythnew\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222\commonfiles"' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 2###### Error #######Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\tp\IntelCompiler\WINX64.7z:'"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\tp\IntelCompiler\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 2###### Error #######Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\tp\intelmkl2021.3.0\WINX64.7z:'"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\tp\intelmkl2021.3.0\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 2###### Error #######Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluents\WINX64.7z:'"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluents\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 2###### Error #######Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluenta\WINX64.7z:'"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluenta\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 2###### Error #######Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluentp\WINX64.7z:'"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluentp\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 2###### Error #######Error extracting C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluent3ddp\WINX64.7z:'"C:\Users\QIU\AppData\Local\Temp\ans_install_tmp38464\7zip\7z.exe" x -aoa -bb1 "C:\Users\QIU\Downloads\ANSYSACADEMICSTUDENT_2022R2_WINX64\fluent3ddp\WINX64.7z" "-oC:\Program Files\ANSYS Inc\ANSYS Student\v222"' terminated after 1 attempts with the following error(s):Unknown errorExit Code: 2>>>--------------------------------------->Please take a look.Thank you. -
September 15, 2022 at 2:52 am
r10543101
SubscriberSorry, is there a way to solve this?
September 16, 2022 at 8:51 am
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2606
2088
1319
1108
459
