July 29, 2019 at 8:27 am
Ghost3507
SubscriberFirst of all I am quite confused between these three terminologies: SubModelling, SuperElement and SubStructuring. Does all of them have the same functionality or they are different?
My problem is: I have a very large structure/Assembly composed of specific parts, these parts I know where they are mated/attached to the assembly. For these specific parts I studied static analysis on them separately and I have their results. I want to import the result of each part back to the full structure to lapse the analysis time for other components.
Example: in the IC Engine (I know there is a special analysis in workbench for, but let me use it as an example) we have -for simplicity- The Cylinder Head, 4 pistons, A Crank Shaft and Cam shaft, all of these parts are assembled to the engine compartment, so my plan is instead of studying the engine as a complete structure with all these components, I study every component independently then inherit their results to the Full structure(engine compartment).
My questions is: Does the super-element helps to this operation or there is a different method of doing so ? -
July 29, 2019 at 2:10 pm
sk_cheah
SubscriberSee here for an example of submodeling: http://www.padtinc.com/blog/submodeling_ansys_mechanical/
Substructuring is the method you just described. Each condensed part is called a SuperElement. Here's a good description of it https://www.sharcnet.ca/Software/Ansys/15.0.7/en-us/help/ans_adv/Hlp_G_ADV5.html
Kind regards,
Jason
2080
1293
1106
459
