Submodeling Cut Boundary
    • Stuart Milam
      I am having particular issues with singular-ish behavior at the edges of my boundary cuts... below is a screenshot of the behavior.
      There is additional geometry not shown, but essentially it is a flange that bolts into the 3 holes shown...
      Would cutting through a contact region(s) like this on the edges (contact = plate to flange) cause this behavior?
    • Ashish Khemka
      Hi Stuart,
      You should not have cut bcs defined at the region of contact/ cut through contact region.
      Performing Submodeling in Ansys Mechanical — Lesson 6 - ANSYS Innovation Courses
      Ashish Khemka
    • Stuart Milam
      Thanks Ashish.
      If i place the cut boundaries "far enough away" from the region(s) of interest (stress concentration), is the simulation results still valid around the stress concentration?
