Submodelling with Multiple object Model
    • mert.dedebeyoglu
      When i try to run the submodel, the contacts not working. I am using cut boundary constraint option.
      I suppressed a couple of parts in the original model and add a new part to the analysis. I am trying to get displacement and run for submodel with contacts. However, contacts not working in displacement imported step.
      Is is possible to use contacts in submodelling in ANSYS.
    • Erik Kostson
      Hi
      Contacts in submodelling can be used,
      as submodelling on a static system is the same as a normal static system (including contact definition etc.), but with the adddition that we have the
      Submodeling / Cut boundary loads on the static system that represents the submodel.
      Erik
