Substructuring in ansys workbench
    • tumulpurwar
      Substructuring is a technique in which a stiffness matrix is used to replace a large section of a finite element model in order to reduce the overall cost of the analysis(in APDL).
      How to use such technique in Ansys mechanical?
    • Chandra Sekaran
      In Mechanical this is called 'Condensed Geometry'. Under "Model" you can insert 'Condensed Geoemtry'. Mechanical does a very good job of automatically identifying the master DOFs , file handling as well as expansion pass. Top-down substructuring has been supported for quite a while. Now you can also export the condensed geometry and re-use it.
      Refer to https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/wb_sim/ds_condensed_parts.html for documentation
