TAGGED: ansys-hfss, antenna, antenna-design, antennas, hfss
September 26, 2023 at 7:10 am
imtiaz
SubscriberHello, good people. In HFSS, I'd like to subtract this empty rectangular wall from this solid rectangular object. However, if I subtract this using normal operations, the middle portion of the solid object remains on the design; I want to cut the entire middle section (even the middle section of the rectangular wall is an empty hole).
Is it possible in HFSS?
Thank you.
September 26, 2023 at 10:38 am
Navya C
Ansys EmployeeHi imtiaz,
I did not understand why you have drawn the empty rectangular wall(Green ) that way if you want to get rid of the centre portion. You can create a sold-empty block that covers the entire middle portion and subtract.
But if you want to do it in the same way you did, you can draw another cube that fits into the middle portion of the design and then subtract it from the (red) cube/wall. While doing that do not select the clone tool part before operation.
Navya
- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3151
1680
1470
