Suggestion for converging result for the abrupt change in the contacts.
    • Sumaya061
    • Ashish Khemka
      nnPlease use a Contact Result Tracker to see the change in Contact Status:nnnAnsys employees cannot download the attachment. A change in the contact status may not be the reason for non-convergence. Can you share the snapshots of the setup and the error message you see?nRegards,nAshish Khemkann
    • Sumaya061
      I tried to upload the wpbz file but it exceeded the limit of 100 MB. Is there any way I can upload an downloadable attachment of the file for possible solution for convergence? n
    • Ashish Khemka
      nnAnsys employees cannot download the file. Can you share the snapshot?.Regards,nAshish Khemkan
    • Sumaya061
      n
    • Ashish Khemka
      nnThe mesh looks too coarse. Can it be refined? Are all the contacts bonded? Any reason to change the Newton-Raphson option to Full? How much force are you applying?.Regards,nAshish Khemka
    • Sumaya061
      If possible to download you can decompress to check out the file. n
    • Sumaya061
      nIs the problem due to mesh refining then I can try to define refined mesh can you suggest optimum element size for that? nYes defined all the contacts to be bonded with each other as suggested before. nI did the Newton Raphson to be defined as full as I was checking the solution in the mechanical help where it suggested to use the Newton Raphson option to use as full control.nI was applying 10 N compressive load from the above keeping the lower surfaces fixed. n
    • Sumaya061
      I uploaded another zip file let me know if it is accesible or not. If it is can you modify the settings to make it converge if possible or suggest me for making possible changes? n
    • Sumaya061
      I could not access the following link-nCan you give me suggestions of the content? n
    • Ashish Khemka
      Hi Array ,nnTo access Ansys Help please use the following link: ,nnTo access Ansys Help please use the following link:nAlso, for bonded can you try using an MPC formulation? Check for Contact Initial Information before running the analysis to see if the contact is established (closed in this case) or not.nnRegards,nAshish Khemkann
    • Sumaya061
      nOkay I am going to try mpc formulation in preprocessing. nApart from that was it possible to access the workbench file? Would you highlight any other points based on the current settings? n
    • Ashish Khemka
      nnI am not allowed to download the attachment. Please see if MPC formulation helps.nnRegards,nAshish Khemkan
Viewing 12 reply threads
