TAGGED: 3d-geomertry, cfd-icfluent, conformal-design, mesh-conformal, meshing, spaceclaim
May 4, 2023 at 7:07 pm
skdubey
SubscriberHi Friends,
I am doing meshing with the outlet flow but my mesh is extermely fine, I also need the mesh to be conformal. I am not able to control the meshing for the square region, If I provide any division my whole mesh is getting distorted even, If I save the workbench and come back, I need to do re-mesh. I have been stuck for week on this.
I tried all the different geometry decompositon and all and all they results in the similar issue as above. any suggestion will be really helpful. My body is fluid domain.
May 5, 2023 at 4:34 am
Keyur Kanade
Ansys EmployeePlesae provide more information. Is this 2D or 3D? What kind of mesh you need? How many bodies are there? Please provide some more images with explaination.
Please check following videos
Ansys Meshing Sizing:
https://www.youtube.com/watch?v=w4q6q8nKF3UDM Share topology:
https://www.youtube.com/watch?v=IO4ZtwZdD2ISpaceClaim Share topology:
https://www.youtube.com/watch?v=h43E1YO1LiMAnsys Meshing: Decomposition for hex meshing:
https://www.youtube.com/watch?v=P19GOTQWmc0Ansys Meshing: Meshing Methods:
https://www.youtube.com/watch?v=nEOC8rDnnRoAnsys Meshing: Inflation:
https://www.youtube.com/watch?v=lrEHXizrhC0Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
May 5, 2023 at 12:12 pm
skdubey
Subscriber@keyur
Its multi-body. and 3D fluid domain. Cross section is around 0.1mm and very thin. Center one is the flow outlet and one trapezodial is the inlet. The inlet and outlet both have extended leg downward on the opposite side. I am looking to create the radial mesh from the center but since that can cause singularity issue, I created the square type in order to over come. But when I start meshing, its difficult since I am not able to control the divison of the square one , whenever I do the entire meshing get distorted and I am looking to create conformal mesh, In the non-confromal meshing I use to get the good results but across the cross section, the flux doesnt match, and I tried to use the interface such as coupled wall but it started giving error, since there are large number of bodies involved. We are looking for 10 to 20 element at the cross sectional as well. The other problem is that with 4.4M nodes, it was easy to run with the laminar model in 20min but for Turbulent model, it started taking almost not working.
May 5, 2023 at 12:21 pm
Keyur Kanade
Ansys EmployeeFor meshing query you need to give more images of the geometry and issue.
In general what I understand it you want to change edge meshing of central square.
You can do that using edge sizing and you can also use biasing.
https://www.youtube.com/watch?v=w4q6q8nKF3UPlease go through help manual for more details
Keyur
May 5, 2023 at 12:38 pm
skdubey
SubscriberHmmm, I have enlcosed the spaceclaimfile, I hope it helps.
Link: https://drive.google.com/drive/folders/1qLGPd6XwefQAzzH9uucceGaJxBaYXk3N?usp=share_link
May 5, 2023 at 12:59 pm
Keyur Kanade
Ansys EmployeeAs Ansys Staff, we can not download attachments. Please upload images using upload image functionality.
You can use some sketches to define the issue.
May 5, 2023 at 1:20 pm
skdubey
SubscriberHi Keyur,
Bottom side
Top Side:
May 5, 2023 at 1:48 pm
Keyur Kanade
Ansys EmployeeSo as I understand after tha middle square, the mesh is having jump. Please use edge biasing in meshing. Please go through help manual for more details Regards, Keyur How to access Ansys Online Help Document Guidelines on the Student Community Fluids Engineering Courses | Ansys Innovation Courses -
skdubey
Subscriber@keyur any suggestion
May 5, 2023 at 1:54 pm
skdubey
Subscriber@keyur, I did that there are two ways, how can I do
1st Way: I start meshing from the outer and then go inward, I use the 3 type of compenent meshing, Sweep meshing, edge meshing and for thickness I use again the edge meshing. (like I need 10 elements). and I mesh the trapz Inlet as well in the same way, and move towards the interior. The time When I reach at the segemented inner circle, I start to lose the control of meshing any changes here can cause the distrotation in the whole mesh.
2nd way: I did was doing from inside but the mesh at the trapz inlet become not so good and distorted as well. Really lead me bit frustrated its just simple geometry.
May 10, 2023 at 9:24 am
Keyur Kanade
Ansys EmployeePlease start from inside and then go out. Please change biasing factor and number of elements to get smoth transition.
5290
3311
2471
