October 15, 2023 at 9:41 pm
Zoelle Wong
SubscriberHi,
I'm new to ANSYS and I'm trying to use SCO2 as my fluid material. My application is flow through a Converging - Diverging nozzle. My current mesh reached a converged solution when my fluid material was air. I switched to SCO2 as my fluid material, whereby I use the NIST real gas model instead of an ideal gas model. However I get the following error message
I'm fairly certain my boundary conditions (mass flow rate inlet, pressure outlet) and initial conditions are correct but I'm not sure what else could be contributing to my error. Does anybody have experience with this? Thank you so much in advance
October 16, 2023 at 5:40 am
SRP
Ansys EmployeeHi,
I suggest you to check fluent user's guide: 8.16. Real Gas Models (ansys.com)
Hope this helps you.
October 16, 2023 at 1:24 pm
Zoelle Wong
SubscriberYes I already have read the manual and followed through with the TUI commands for activiating the NIST real gas model. I'm fairly certain my intial temperature and boundary condition temperature is correct; I'm not sure if the temperature being "low" is a result of a meshing or numerical stability. Can you put me in touch with someone who has experience on this application? There is literature of ANSYS being used for SCO2, but the posted literature doesn't give a "step by step" guide on the inputs they used for convergene. Thanks again
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1478
