Supersonic outlet boundary condition
    • Abubakar
      Hi sir,
      I have a question related to outlet boundary condition for supersonic flow.
      What I have a read is in supersonic flow static pressure can't propogate back Upstream faster then wave speed so, I didn't understand this statement can anyone explain me this thing in brief? TIA
    • Surya Deb
      Yes , for supersonic outlet conditions, the static pressure at the outlet is extrapolated from interior cells. So the specified pressure will no longer be used. The reason for this is as you have mentioned already.
      Regards SD
    • DrAmine
      At supersonic inlet you specify everything at supersonic outlet nothing you specify will be used.
