Discovery Import
Discovery Import
Supported NVIDIA card with minimum memory reported as not meeting the minimum 4GB
    • wess.gates
      I have a NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 which has the 4GB min and is documented to be compatible with the Explore stage. However, I get the warning "Explore stage may not run properly because your graphics card has less than the required 4GB of memory" Similalry I get the warning when running the compatibility utility:
      • Graphics device is not compatible with Discovery Explore stage.
        • This machine does not meet the minimum hardware requirements.
        • Discovery requires a minimum of 4 GB of graphics memory. Discovery may not run properly because your graphics device does not have the minimum required memory.
      The drivers are reported correctly by the utility:
      GPU Information:
      GPU 1: NVIDIA GeForce GTX 1050 Ti
      Driver version: 30.0.15.1165
      Driver date: January 2022
      GPU 2: Intel(R) HD Graphics 630
      Driver version: 30.0.101.1340
      Driver date: February 2022
      CUDA Information:
      Driver CUDA version: 11.6
      Required CUDA version: 11.3
      CUDA Devices:
      GPU: NVIDIA NVIDIA GeForce GTX 1050 Ti
      Graphics Memory: 4095MB
      Compute capability: 6.1
    • Charudatta Bandgar
      Hello Wess Gates
      Let me check this and get back to you.
      Hello Wess Gates
      Although minimum 4Gb is required, 8 GB dedicated GPU RAM is recommended. NVIDIA GeForce GTX 1050 Ti is a GeForce Card. Discovery may work on GeForce cards, but not officially supported since there is no testing done for the same. I would suggest you update the graphics card drivers from the manufacturers' website and see if that helps (avoid the 5xx.x graphic card driver, as it has shown some other issues).  Since you have multiple graphic cards, as a next step make sure you check whether right card is applied.
      Regards
    • wess.gates
      Hi Charudatta Bandgar
      It appears that your suggestion to roll back to an older driver resolved the problem. I have had Discovery for 3 years and it has not previously given this warning. Thank you for the support. In case this is helpful to anyone here is the output of the compatibility checker after rolling back to an older NVIDIA driver.
      The Discovery Compatibility Checker results are as follows:
      • Graphics device is compatible with Discovery Model stage.
      • Graphics device is compatible with Discovery Explore stage.
      • Graphics device is compatible with Discovery Refine stage.
      GPU Information:
      Driver version: 30.0.14.7284
      Driver date: December 2021
      CUDA Information:
      Driver CUDA version: 11.4
      CUDA Devices:
      Graphics Memory: 4096MB
Viewing 3 reply threads
