Preprocessing
Preprocessing
Suppress Mesh Updating
    • Manu19
      Hey Guy´s,
      i´m using a Parameter Set to get the Polarplot from an Airfoil. I have also definded the Velocity in X and Y Direction of the flow at the CFX-Pre Setup for every Design Point. There is no difference between the Geometry of the Design Points. If i start the update Process for all the Design Points it updates the Geometry and the Mesh, too. How can I suppress the new generation of the mesh and use the same mesh again and again?
      Thanks for answering,
      Manuel
      If you have parameters in geometry & meshing it'll check those settings before running the simulation.  Try removing parameters from geometry/meshing and see what happens.
    • Manu19
      Thank you!
      I didn´t recognice that i have defined a New Coordinate System which uses some Input Parameters.
