Surface area calculation
    • Kalyan Goparaju
      How to calculate the area fraction on a surface where a variable is less than a certain percentage of the average variable and monitor this area fraction during the run?n
    • Surya Deb
      Hello Kalyan, nThe area fraction on a surface where a variable is less than a certain percentage of the average variable can be calculated with the following expressions. nA report definition can then be created based on the uniformity expression to monitor the value during the run. nthreshold = 0.1 navg = Average(StaticTemperature,['outlet'],Weight ='Area')n areaoutlet = Area(['outlet']) nuniformity = Sum(IF(abs(StaticTemperature-avg)/avg
