Surface coating meaning
    • KevinsYuan
      Hi everyone,
      i find out this option (Modell - Geometry - insert "Surface Coating") here, can anyone tell me what is the meaning of "Suface Coating" in Ansys?
      I just intressted about the stress underneath the coating, will the result be the same with a real geometry (in [um] thin) of surface coating if i use this option. The thickness of coating is to small relative to other parts, for example 5 um vs. 20 mm, sothat i have difficulty to mesh the entire part.
      Thank you very much!
      Reguard
      Kevin
    • peteroznewman
      Please read this page of the ANSYS help.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/wb_sim/ds_surface_coating.html
      Please read this Discussion about how to use the link above.
      The answer is yes, you can get the effect of a thin coating of some other material to a specified thickness on top of a solid body. You can look at the stress on the surface of the solid as well as the surface of the coating.
