September 16, 2018 at 7:29 pm
balsaidi
SubscriberWe need to perform shear test study. Our model consists of multiple components that have capability to slide on each other. We need to define No separation or frictional contacts type between certain surfaces. Model fails to run!
Please see the attached pdf file for clarification.
Thanks,
Bashir
September 16, 2018 at 8:19 pm
Sandeep Medikonda
Ansys EmployeeBashir,
Please try the suggestions provided in this discussion which should help with this error.
Sandeep
SubscriberBashir,
Not everyone here can open attachments, so below is an image of what you attached above.
The reason the solver fails in this shear force model is that there is no resistance to the force, therefore the displacement is infinite, which causes the solver to stop.
You can have a solution if you use Frictional contact with a non-zero coefficient of friction, AND apply an X direction tension force to create a normal force on the contacting faces, so that there will be something for the coefficient of friction to be multiplied by to generate a shear force AND apply a shear displacement, not a shear force, since if the shear force is greater than the frictional force, you will again have an infinite displacement.
September 16, 2018 at 9:13 pm
September 16, 2018 at 9:14 pm
balsaidi
SubscriberThanks Sandeep!
Bashir
September 16, 2018 at 9:36 pm
SubscriberBashir,
Did you turn Large Deflection to On under the Analysis Settings?
You should insert a Contact Tool under the Connections folder and Generate Initial Contact Status. If all the frictional contacts are not closed, then you have to take some corrective action.
You need to break the solution into at least two steps.
In step 1, the 10 N force is applied, while the tangential displacement is kept at 0 mm.
Then in step 2, the tangential displacement of 10 mm can be ramped on gradually.
Getting the model to converge in step 1 may require Auto Time Stepping to be changed from Program Controlled to On and the Initial Substeps to be set to 10 or higher.
I remind you of the advice I gave before to suppress all but 3 links. Make the left link fixed, let the center link have contact on either side and let the right link have the X force and Y displacement. Get this working before you try to solve with more than 3 links.
September 16, 2018 at 9:51 pm
balsaidi
SubscriberPeter,
Still unable to run. Do you mind check it for me please? Attached.
Thanks,
Bashir
September 16, 2018 at 10:40 pm
SubscriberBashir,
Get Step 1 running, the tension force along X, before worrying about step 2, the shear force.
You have to set the mesh to have more than 2 elements through the thickness. This mesh has only 1 element through the thickness, which is inadequate.
Use the Mesh Sizing setting for Proximity with 2 elements across the gap with a minimum gap of 0.5 mm.
Unfortunately, this is going to create a very big model that will take a long time to solve.
You will be better off extracting the midsurface from this solid body and meshing shell elements on a surface body.
Build a model to put a tension force on those.
Attached is an ANSYS 17.2 archive of a surface model that has an assigned wall thickness of either 1 or 2 mm.
September 21, 2018 at 5:21 am
balsaidi
SubscriberHello Peter,
I made your suggestions, 3 components of shell. Issues are, I couldn't make more than one layer of mesh elements as you did for these shells.
Also, I had to define surface contact regions manually since the system couldn't detect them automatically.
Still unable to run solver! Your suggestions please.
Thanks,
Bashir
September 23, 2018 at 2:23 am
SubscriberHello Bashir,
The solver failed because the contacts were not closed when it started.
The contacts were not closed because you didn't turn on Shell Thickness Effect.
The contacts were not closed because you didn't expand the geometry until the point where the faces are touching.
I explained previously that you can only start solving when the faces that have to push on each other are touching.
If you want to learn how to use contacts in ANSYS, you should start with a simple example and work your way up to more complicated cases. This model is complicated and I recommend you return to it after you have demonstrated success on simple examples.
October 5, 2018 at 1:16 am
balsaidi
I am confusing regarding your suggested method for running a model, do you mean I need to apply tension force only at step one till see the result of applying this force along x-axis then I rerun the model in step 2 which is by applying the shear displacement only along y-axis?
Thanks,
Bashir
October 5, 2018 at 8:21 am
In the Geometry editor, you have to make the parts touch before you mesh them and apply loads and supports.
Then you apply a tension force in x direction in step 1, and a shear displacement in y direction in step 2.
October 5, 2018 at 11:12 am
Ashish Khemka
Ansys EmployeeHi Bashir and Peter,
I was thinking of an alternate approach - apply a known displacement, say in step 1 to close the gap and then apply the required force in second step. Also please see if adjust to touch helps.
Ashish Khemka
2098
1327
1110
461
