Surface definition
    • javdijaj
       I would like to know if it is possible to extract the surfaces and points from a fluent case set-up ?
      The goal is to create those surfaces and points in another fluent case instead of creating them manually through the Results>Surfaces tab.
      Thank you.
      J.Avdijaj
    • Nilay Pedram
      You can try writing the profile to export the solution data from one file to import into another.
      Thanks.
