Surface Energy
    • CP14
      I am running a simulation of my structure through water. I was wondering if it was possible to run a calculation that will determine the surface energy between my structure and the water.
      You can extra forces etc, what energy are you looking for?
    • CP14
      Im looking for the surface energy of my part while it is in water. In other words the inter facial surface tension between my part and the liquid.
    • DrAmine
      No not possible: you first require to do an multi-phase run and make fine grid and still that will require your input. Surface energy or surface energy density (surface tension) is a user input.
Viewing 3 reply threads
