June 29, 2020 at 9:39 am
DESOJIB
SubscriberHi,
I am apply load on a surface using APDL script. i want to know if i apply the same Force value using different Command SFE and F then does it makes any difference in my result?
Greetings,
Bhavin
June 30, 2020 at 10:36 am
Aniket
Ansys EmployeeI hope you have checked the help already:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/ans_cmd/Hlp_C_SFE.html
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/ans_cmd/Hlp_C_F.html
SFE is applied on surface elements, while the F is applied on nodes. I would recommend using it on a simple taste cube and test to see the difference!
-Aniket
June 30, 2020 at 10:50 am
DESOJIB
SubscriberHi Aniket,
Thanks for your reply. I checked Ansys Help and i came to know exactly what u mentioned that SFE applies on Element and F applies on nodes.
i Have one more question i am doings Harmonics response solution and i have Force as a table in real and complex component as different frequency. can you please mention how can i do it using SFE command.?
i created SURF156 elements on the surface where i want to apply the load but using SFE command i am geeting error. Please find Force table in Attachment
Thank you
July 1, 2020 at 3:35 pm
Aniket
Ansys EmployeeOk and what is the error that you are getting here?
July 2, 2020 at 7:29 am
DESOJIB
Error i am getting is : there are no degrees of freedom active error ansys
3820
2607
1853
1244
600
