March 28, 2022 at 9:04 am
ooseren
SubscriberHi Everybody
How to assign surface hardness to part in ansys ? For example ; There is Ø60 shaft and the distribution of the hardness is like that. Surface hardness is 55 HRc (From surface to 9mm) and The core is 42 HRc.
Thank You
March 28, 2022 at 2:06 pmAshish Kumar
Forum Moderator
Please see if the following link helps:
Simulation of Vickers hardness test on a substrate with coating - Page 2 ÔÇö Ansys Learning Forum
Regards Ashish Khemka
March 28, 2022 at 5:12 pmDavid Mercier
Ansys EmployeeHi, Yes I agree the easiest is maybe to model a coated sample considering perfect interface between both layer and substrate. Then, you could even model more than 1 layer in the coating to simulate a gradient. And look at this discussion maybe:
https://www.researchgate.net/post/How-can-I-provide-the-material-properties-of-functionally-graded-materials-in-ANSYS-APDL-or-Workbench
Trending discussions- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- About Bilinear Isotropic Hardening Plastic Model !
7676
4476
2957
1433
1322
