Surface Intergal in UDF
    • mohanpannirselvam08
      I would like to write the following Suface intergation formula in a UDF. But i am not sure am i writing it properly. The formula does the following:
      • Get the (v^2+w^2) velocty component value at each face value of the intersection surface within my flow domain (treftz-Plane).
      • Then multiplied it with density and 1/2
      • Then multiplied it with the respective surface area of the face
      • finaly sum all the product value for each face on the the intersection face.
      I have done this with a custom field function dialog box (Image). However as i try to run it in a UDF fromat, i get a totaly different values. Why is this? Am i doing something wrong in the UDF? What macros should i use?
      Surface integration formulaTrfetz Planetrefttz plane in the flow domain at back of the wing
      #include "udf.h"
      enum {     w4 };
      DEFINE_ADJUST(my_adjust,d)
      Thread *t;     cell_t c;     int n;     Node *node;     face_t f;
         thread_loop_f(t,d)
          {     begin_f_loop(f,t)    {
                 C_UDSI(f,t,w4) = 0.5*C_R(f,t)*((C_V(f,t)* C_V(f,t))+(C_W(f,t)*C_W(f,t)));
               end_f_loop(f,t)
      You want to have a look at custom field functions: that may be a better solution.
