April 27, 2022 at 2:22 pm
rg
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hello
When I create a cube or any geometry with a hole, when I go to give it thickness it doesn't create the surface for me why? how do you reset it to how it was before without having to reset user settings?
Regards
April 28, 2022 at 4:23 am
Charudatta Bandgar
SubscriberHello Roberto
Let me look into this. I will get back to you.
Regards.
April 29, 2022 at 4:36 am
Charudatta Bandgar
I think the fill after end sketch itself does not create any surface for the circle inside. I have asked the team whether it is an intended behavior and if there is any way we can go back to the older way.
Regards.
April 29, 2022 at 7:05 am
rg
SubscriberCharudatta Bandgar Hello
I await your news to know how to go back, in such a way that the surface is created
Regards
April 29, 2022 at 11:56 am
Charudatta Bandgar
Although this is an intended behavior, you can chose the option as shown in the video to toggle between the interior kept/removed feature.
Regards.
Sidenote: If this was part of the previous script, it would be necessary to incorporate and adapt it, either by no longer deleting the internal faces by script or by using command: SketchHelper.RemoveInteriors = False.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Unexpected graphics error
- loss of user settings
- Dwg export error
- Can’t see license on online account
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- problem to access on the spaceclaim help
- Unsymmetric result
3720
2570
1775
1236
594
