Preprocessing
Preprocessing
Surface to Surface Contact, Mid-Surface Mesh
    • DoodlerD
      What would be the ideal way to mesh a bonded joint between two structural components using mid surfaces? (ANSYS WB 2014)
      1. A gap with MPC elements and pinball radius (as shown) or
      2. No gap and connected structural components
      I believe the latter will increase mass and rigidity because of the mid surface mesh.
      Thank you!
    • Ashish Khemka
      nnUse MPC contact for bonded as much as possible unless overconstraints exist. It is-n? Ideal for shell-solid, shell-shell, and beam-shell contactsn? Interface with small gap/penetrationn? It avoids spurious frequencies for modal analysisn? Rather than modify the geometry to fill the gap, they cannbe accurately ignored when using MPC Contact or a fixednjoint.nRegards,nAshish Khemkan
    • DoodlerD
      Thank you for your advice, my sumulation was successful n
