Surface to Surface Radiation
    • Jonahbt40
      I had a question regarding how surface to surface radiation works within ANSYS. In particular, the difference between setting the enclosure type to ?perfect? vs ?open?. My current understanding is as follows. In a perfect enclosure, all radiation emitting from every surface adjacent to the enclosure ends up striking the other surfaces and none is lost to the environment. In a open enclosure, if ANSYS determines that a particular ray of radiation would not strike any of the other surfaces, that radiation is treated as ?ambient? radiation and is radiated off the environment. Is this a correct understanding? n
      Sounds reasonable, but we account for all surfaces in the ray tracing and then decide what happens at the surface: I don't recognise the perfect/open enclosures from skimming documentation but it's also not my area of expertise. The model is described in both the Fluent User's Guide and Theory Manual n
