June 15, 2020 at 3:48 am
Weiqiang Liu
Hi all,
I am trying to model hydrogen combustion in porous zone with fluent. The temperature of the porous solid and fluid is different. However, I did not use non thermal equilibrium model in fluent. Instead, I used a UDS to solve transport equation of solid temperature and I defined a volume convective heat transfer rate between solid and fluid.
When setting the reaction panel of the fluid panel, I am confused about the surface-to-volume parameter. I think this is a parameter that is used in non thermal equilibrium model of fluent. Because I noticed there is a convective heat transfer rate hv defined in the default non thermal equilibrium model. With this hv and surface-to-volume ratio, fluent solver can calculate volume heat transfer rate.
My question is: since I am using my own non thermal equilibrium model and solid temperature equation are solved by UDS. Therefore, I can leave this surface-to-volume parameters to a random number.
Am I right?
Best regards
Weiqiang
July 21, 2020 at 3:41 am
wcao
Ansys EmployeeHi Weiqiang,
The surface-to-volume ratio as shown in the your post is for surface reaction instead of thermal purpose so that it appears under the reaction tab. For more details, you can refer to the theory guide: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/flu_th/flu_th_sec_species_surface_bc.html?q=surface-to-volume%20ratio
Thanks.
Weiyu
July 21, 2020 at 5:51 am
Weiqiang Liu
SubscriberHi Weiyu,
Thanks very much! I geit it.
best regards
weiqiang
3812
2607
1853
1244
600
