3D Design
3D Design
surfaces from sketch
    • rajdipjag
      i am having doubt that, in spaceclaim that how to convert sketch into the surfaces?
    • peteroznewman
      If the sketch is a closed profile, when you click the 3D mode button (the solid cube icon on the bottom edge), the curves will be replaced with a surface that can be pulled into a solid.
    • Keyur Kanade
      Yes, as Peter has mentioned, once you switch from 2d to 3d, SpaceClaim will create surfaces.
      Are you importing any sketches? Does it have curves? Are you importing images?
      Keyur
    • Keyur Kanade
      Is your issue resolved?
      Keyur
Viewing 3 reply threads
