October 5, 2018 at 7:25 pm
October 5, 2018 at 7:28 pm
sameerfares
Subscriberi think i figured it out. I used Fill. Is that the correct way?
Thanks,
Sam
October 5, 2018 at 7:31 pm
sameerfares
SubscriberBut when i tried to extract a beam from this solid it failed. Not sure why?
Thanks,
Sam
October 5, 2018 at 7:51 pm
desouzadacosta
SubscriberI can try, Can you upload the.scdoc?
October 5, 2018 at 8:00 pm
sameerfares
Subscriberi just uploaded the file.
Thanks,
Sam
October 5, 2018 at 8:11 pm
SubscriberHi Sam,
Can you try Windows Snipping Tool instead of whatever you are using for screen snaps?
My scroll wheel is getting worn out scrolling to the bottom of your posts with the long whitespace in the image.
To make a solid from those surfaces, go to the Repair tab and use Stitch to connect all the surfaces together, then use the Missing Faces tool to make a solid.
October 5, 2018 at 8:22 pm
sameerfares
SubscriberHi Peter,
I have been using windows snipping tool then pasting to document then save as JPEG, then i insert the image by picking the document. i am sure there is a better way.
Once i use Windows Snipping Tool and snip the image then what is the next step?
Thanks,
Sam
October 5, 2018 at 9:17 pm
SubscriberHi Sam,
After you use the Snipping Tool, Save with the tool. It doesn't matter if you save as .png or .jpg. Insert the image by picking the .png or jpg file you saved in the Snipping Tool. Don't paste it into a document and then insert the document. That is causing your images to have a size of 1020 x 1320 pixels, which is a lot of whitespace.
You could install Greenshot, which is superior to the Snipping Tool because it is launched by pressing the PrtSc button on the keyboard.
October 5, 2018 at 10:24 pm
sameerfares
SubscriberInstalled Greenshot. Thanks Peter!
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2148
1359
1150
462
