May 10, 2022 at 11:19 pm
LuisAlbert
SubscriberHello everybody,
I am simulating a straight waveguide, but right now I want to see the behavior of GVD as a function of the width of the waveguide. How can i do it? I know that I have to Sweep the waveguide dimension but I am struggling with that.
I really appreciate your help.
May 11, 2022 at 7:49 pmGuilin Sun
Ansys EmployeeYou can write a simple script to sweep the width, and follow this example to get the result:
https://support.lumerical.com/hc/en-us/articles/360034925153-frequencysweep-Script-command
Please note that you when you do frequency sweep, you can just use the same frequency as the stop frequency as internally the software will get accurate result.
Your script may look like this:
define the width matrix with ND points
define GVD result matrix
for(n=1:ND) {
modified online example;
GVD(n)=D;
Please try.
Viewing 1 reply thread- The topic ‘Sweep in waveguide dimension’ is closed to new replies.
Trending discussions- Ansys Insight: About override mesh in FDTD: its use and settings
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3153
1680
1470
