Photonics
Photonics
sweep problem
    • jb2nn
      I tried to set up a sweep in FDTD solver .But it failed. Would you mind helping me to solve this problem?
    • Lito Yap
      @jb2nn,
      Based on the error message, it cannot find the file on the said folder. Could also indicate permission/access issue on the folder. Did you create the folder “C:\UVA…\” where the simulation file is currently saved?
      Try to run the example from the Application Gallery > Parameter sweep utility – Ansys Optics. Save the simulation file into your User’s directory i.e. Documents, Desktop, Downloads or create a new folder in Drive “C:\” to ensure read/write access on the folder.
