symbols i don’t understand
    • Walaa Elhamamy
      hello,
      what are these things which appear on my drawing? I marked them on black boxes.
      and how to remove them
      Forum Moderator
      What are you plotting? The two red items look like velocity vectors, not sure about the black thing.
    • Walaa Elhamamy
      I was creating a line from the surface, and when I ticked on "line" as seen in the screenshot, this thing appeared.
      Forum Moderator
      Which direction is z?
    • Walaa Elhamamy
      Downwards is -z.
      Forum Moderator
      So the line in the panel isn't the same as the black line on the plot.
    • Walaa Elhamamy
      No, and it disappeared when I started to run, I am not sure if this will affect anything.
      Forum Moderator
      Lines won't effect anything. As we're still unsure what the other marker was I'd be very carefully checking the mesh & results.
    • Walaa Elhamamy
      ok, thanks for your reply
Viewing 8 reply threads
