Symmetric results
    • HusseinK
      Hello all.
      So I have created a model, a room where air enters from an opening in the middle on top and exits on the sides, the air goes through an air diffuser which is a disk with multiple holes with same diameter, I run the model and everything goes smoothly and I get convergence.
      The problem is when I look at temperature contours of the ceiling, its supposed to be same on each side since the holes are exact boundary conditions, but what I get is is not uniform contours. What could be the cause, here is a picture of what I get.
      Thank you guys!
    • Kalyan Goparaju
      Can you please include the color bar so that there is some context to the colors? Also, was this a steady state or a transient simulation?
      Thanks,
      Kalyan
    • Keyur Kanade
      is it 2d or 3d?
      what is residual criteria used?
      can you put some arrows to show inlet, outlet and flow direction.
      Keyur
    • HusseinK
      sure thing let me add it, its a steady state case.
    • HusseinK
      its a 3d case, its like you are looking at the room from the top, and the circle is the air inlet, I was to study the temperature distribution on the ceiling, and these four edges have same B.C
Viewing 4 reply threads
