January 20, 2023 at 7:00 am
micaelaolivetti31
SubscriberHello!
I performed a static structural simulation with Explore on a symmetric model. Is it possible to show the obtained results on the whole geometry and not only on the symmetric part used for the calculation?
Thanks and Regards
Micaela
January 20, 2023 at 10:02 am
Devendra Badgujar
Forum ModeratorHello MicaOli
I will check and get back to you.
January 20, 2023 at 11:43 am
Devendra Badgujar
It is not possible to obtain results on the whole geometry for symmetric model at the moment.
I will raise an enhancement request for this functionality to added in the future releases of Discovery.
Thank you.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7742
4502
2957
1449
1322
