June 30, 2019 at 8:05 am
Abdoon075
SubscriberHi there ...
I want to symmetry the stiffened panel, but it symmetry the plate and leave the stiffeners
June 30, 2019 at 10:42 am
SubscriberPlease use the Insert Image button to put your image into your post.
ANSYS employees are not permitted to open attachments.
June 30, 2019 at 12:13 pm
June 30, 2019 at 5:11 pm
SubscriberOpen ANSYS Help > DesignModeler User's Guide > 3D Modeling > Advanced Features and Tools > Symmetry... where you can read this:
The Symmetry feature is a tool used to define a symmetry model. The feature takes either all the bodies or selected bodies of the model as input and accepts up to three symmetry planes. You can choose either full or partial models to work with. If a full model is used, the selected symmetry planes will slice off the model and only a portion of the model will be retained. The valid body types for this feature are surface and solid.
Beam are not supported, so you will have to trim them manually and provide the appropriate boundary conditions manually.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3694
2564
1765
1236
592
