Tagged: axisymmetric, dynamic-analysis, modal, modal-analysis, structures, symmetry, vibration
September 5, 2022 at 12:42 pm
minghui.dai
SubscriberCurrently, I meet problems on the symmetry boundary applied in vibration simulation for a axisymmerty
model. Symmetry region boundary setting seems not to support modal analysis & dynamic analysis.
As pictures shown below. when using symmetry region boundary, it can't get all the modes.
2 discussion points on symmetry structures simplification for vibration simulation:
- When setting the symmetry region boundary, whether are there solutions to getting all modes in 1 model analysis? so that it could continue the harmonic or other dynamic analysis.
- Are there other simplification methods to deal with a symmetry model? such as setting a remote point.
September 7, 2022 at 1:47 pm
Florian.CHANCEL
SubscriberHello,
In Modal or buclking analysis, symmetry cannot be used, because the resulting diplacements are not symetric.
I think, it's not possible to use other method like Remote point, or something like this.
Regards,Florian
September 8, 2022 at 12:41 am
minghui.dai
SubscriberHello, Florian,
Thank you for your information, I learnt from the help document and some vedio introduction, indeed, the symetric region couldn't be applied in model & dynamic analysis.
I still hope there are a method to do simuplication due to it's too complex to deal with the whole models.
September 8, 2022 at 5:42 am
Florian.CHANCEL
SubscriberI saw an option for axisymmetric solid model (it doest not work on beam model).I never used it, maybe you can try ?It’s the option “General symmetric” in Symmetric region definition. This option removes the restriction to have loading and deformation responses neet to be axisymmetricat 6 min 30 -
September 9, 2022 at 11:49 pm
Subscriber@minghui.dai
If the whole model is too large to solve, that indicates that more effort needs to be expended in idealizing the model. Changing Tet mesh to Hex mesh, changing solid elements for shell or beam elements. That way, a large reduction in node and element count can be realized and the whole model can run.
2120
1347
1118
461
