March 29, 2022 at 9:52 am
sampathkumar
SubscriberHello .....
I designed synchronous reluctance motor in the MotorCAD tool. Here I observe that the rotor bridges are getting saturated .May I know how to give the rotor barrier end angles in MotorCAD
March 29, 2022 at 12:29 pmNavya C
There is a "Bridge thickness" parameter in the motor if you want to increase the thickness of the bridge.
Can you show on the image what do you mean by "rotor barrier end angles"?
Regards Navya
Ansys Innovation SpaceTrending discussions- simulation completed with execution error on server
- Maxwell, HFSS or Q3D?
- Error
2600
2088
1319
1108
459
