Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Synchronous reluctance motor design
    • sampathkumar
      I designed synchronous reluctance motor for rated torque at 20 V . But after simulation i found that the rated torque is getting at 25 V.... May i know how to correct it... Else it can be corrected by control design for the motor
    • Ivonne Marti
      Hi Sampathkumar,
      Please check the following points:
      1/ is there is any mistake in the setup?
      2/ the mesh quality in the airgap.
      3/ are you including core loss and eddy effects in the calculation?
      I hope it helps
      Ivonne
