March 7, 2019 at 12:59 pm
Simon95
SubscriberHi,
I`m a begginer with Ansys-Fluent so I need some help. I want to study flutter condition of an airfoil with Ansys, so I want to do a 2-way FSI with System Coupling. I have done the transient structural module and the fluid flow one, but when I connect both setups with the system coupling one, there is no participants in it.
I have the free student version, and I know that system coupling module needs Academic version to work so I have already change the license preferences to Ansys Academic Introductory into the firts place, with `Share a single license between applications when possible'
The error that appear says
DP 0) The Setup component in Fluid Flow (Fluent) requires user input before it can be updated. For instructions on how to address the cell in its current state, click the blue triangle in the lower right corner of the cell in the Project Schematic. .
Can anyone help me please? Thank you.
March 11, 2019 at 1:18 pm
BeginerModel
SubscriberI was under the impression the student/academic edition couldn't use system coupling but i might be wrong. The most common time I get that error is when I forget to add the time step size in fluent.
March 2, 2020 at 5:53 am
rupalipandey
SubscriberHii simon95. Did you find an apt solution to your problem?
March 2, 2020 at 4:27 pm
Ansys EmployeeHave a look through the tutorials and videos: they should give you some pointers.
July 17, 2020 at 10:09 pm
HossamMedhat
SubscriberHey Simon95,
Did you find a solution for this problem ?
- Changing of font size
- System Coupling
- ANSYS Workbench Mechanical Solver problem after saving
- ansys with matlab
- 3D ROM in workbench
- Error message “Solver pivot warning” due to element birth and death
- ANSYS Direct Optimization
- HARDWARE COMPATIBILITY
- System Coupling
- When I open the Electronic Desktop, Twin Builder auto opens
2524
2066
1279
1096
457
