Ansys Products
Ansys Products
System Coupling detects no participants
    • I-Lun Chen
      Hi, I am trying to run FSI simulation. But when I open System Coupling, there are no participants.
      I wonder how do I detect them from upstream? Thanks.
    • Nikhil Narale
      I would suggest that the first step you could take is to check whether the ‘Setup’ cell in project system B has been completed or updated (I can see a question mark). It’s possible that this could be the root cause of the issue you’re experiencing. So, if you could kindly take a moment to verify this, it may help us to better diagnose and resolve the problem.
      Thank you!
      Nikhil
    • saluf
      Have you been able to sort this problem Chen as I have the same problem? I am unable to select the region and variable in the target tab.
