System Coupling Error
    • itsme_tilak
      While performing 2 Way FSI, I encountered the following error in the first iteration which is depicted in the following screenshot. Can anyone help me to solve this problem?
    • Rahul Mule
      The message means that at least one part in your model does not have enough constraints on it. The solver is producing a displacement of more than 1e6 length units which indicates that it is not solvable. Either add constraints until the message goes away or perform a modal analysis and look for the rigid body mode.
      Hope this helps!
      Rahul
